Dropping connectivity
Cherylchambers
Both myself and husband are now working from home and we have noticed our BB keeps dropping out. Can we do anything about this. Do I need to buy a booster ?
Mustrum
@Cherylchambers  do you know if it is the Broadband that is dropping or if you are just losing WiFi ?
Do the lights on the router change?
No one on here has access to your account or can see what is happening to your line, but you could follow the guidance in the following Help Page to get in touch with the care team.
https://ee.co.uk/contact-ee/technical-support/broadband-landline
