Dreadful Speeds.
RobertMead
My speeds are appalling and they have been throughout my entire time with EE, I have had multiple engineer.cisits, each one.xlaims.to have fixed the issue - it seems to be a different issue each time but the issue is never resolved.
 My speed guarantee is 58Mbps - the latest speed test via the EE shows the speed to my hub is only 41Mbps,  an independent test shows it is 38Mbps.
 Bizarrely I cannot go online and watch TV at the same time, my laptop is connected by WiFi and the TV by ethernet - surely there should be no conflict?? I cannot watch live 4k TV at all and regular HD channels stutter and stop, I've put up with this for close to a year now but I've had enough.
I don't use a phone so my.onky way of contacting EE is through the live chat, and that is dreadful, they just ask me to complete checks I e ready completed then book an engineer, then we're back to square one.
Apart from just giving up and leaving EE, what can I do?
  • For a SmartHub: login and go to Advanced Settings > Technical Log > Information. Obscure your names & any numbers in the BB Username & also the SSIDs. Also post the Home > Status page.
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
