Constant buffering
Uzume7
Hi
My internet access is so unpredictable, it’s practically unusable at times! Constant buffering on tv, internet access dropping so I can’t use my laptop and the only way I can do anything online  is my mobile data. This happens throughout the day so many times it’s driving me up the wall! I have followed all basic guidelines I could find, reboots, reconnection etc but no luck.
The WiFi and internet lights on my router are constantly flickering, even straight after a reboot, does this mean anything? I thought that was normal as it does it all the time.
I’m going to take advice about ending my contract without penalty as it’s not fit for purpose as I can’t do what I need to do!
If anyone knows why this is happening and what to do, please let me know. I’ve done all the basics stated online ie reboots etc so nothing that simple please, as nothing has worked.
Many thanks
The WiFi & Net lights flickering is quite normal as data is moved across them.
