Connectivity Backup
Neil8568
I have just renewed my contract. I have been asked to return my Hub 6, extender and connectivity backup.
I am being sent a hub 7 pro and extender. Why does my new contract not include a connectivity backup device?
I never actually had to use it but it was a nice safety net.
15 REPLIES 15
Neil8568
Thank you. I think in the first instance I will just return it. Then if I decide later to get one I can adjust my contract and get a new one that way rather than one that's 2 years old . Thank you for the replies
@Neil8568 Smart way to do it, the £80 is only the non return fee that EE charges, the rest is for keeping it on a mobile service when needed to be called upon when the Home fibre network is off, with all the reduced features and speeds.
If it's also working the two years is nothing unit wise, keeping it would be way better and you could even see if EE want's to play ball with a reduction for the per monthly cost.
Maxell
When you click on the keep connected promise option on my Ultimate plan it takes you to a page to request a 4g connectivity backup.
@Maxell That is not the same unit EE supply's for that fault condition, OP is not waiting couple off day's for EE to dispatch on the occasion/s when/if it occur's. See below link, more than likely one off these for a temp down.
4G WiFi device | Device Help | EE
Maxell
Yes that looks like it, what else is there,? You can have it all the time for I think £10 per month.
