16-05-2024 12:12 PM
I have recently had EE Broadband installed, though I still have my Virgin Media equipment while the contract runs down.
I have an HP 8020 printer that is connected to the EE router using an ethernet cable but the printer keeps showing unable to connect. At first, when I tried to print a document, it allowed me to press 'connect' on the printer and the document would print. Now, that wiill not work.
16-05-2024 01:13 PM
@EriktheViking1 have you gone back through the setup process via the HP app since you moved the printer to the EE router?
The VM router will have used different settings, so worth doing the setup again.
You may also want to try a different LAN port.
