25-09-2023 08:23 PM
Looking for advice. Just received notification that my package is come to an end this week . Also found out that we are in a telephone withdrawal area and can no longer have a landline. No one at EE can answer how can I make or receive calls after this point. Does anyone know if I change to full fibre would I keep the same number so if someone calls me I would receive the call if I have a compatible phone plugged into the router?
25-09-2023 09:27 PM
@MICKHPOOL if you wanted to keep the ability to use a phone you would need to chose a supplier that offers digital voice, or use a third party VOIP supplier.
Presently EE do not offer digital voice, but BT does, as do other suppliers such as Sky and Talk Talk as well as a few others.
HTH
25-09-2023 10:30 PM
As you currently have a landline you may keep your landline if you keep on your contract or if you regrade to a similar BB plan. The telephone withdrawal area just means no new landlines may be sold.
If you change to Full Fibre you get no voice services with EE.
