Broadband not working
RachGreens6
Hi
Our broadband went off yesterday afternoon. We’ve got a hybrid connect box but this isnt working either. Any idea how we can get the hybrid box to work while the broadband is fixed?
Hi JimM11
Ive tried the suggestions. The box is on aqua but the signal bars are 3 flashing red bars.
@RachGreens6 Then it has been pointed out problem is with the 4g signal, do you have one? Some have suggested pop the sim card out clean and re insert, and question have you ever had it working before?
It's also just not any old sim that goes into the hybrid unit, EE have a special sim that is designed to work as it is just a backup unit, connected but not doing anything until the main BB line goes down. Also link from posting the other day below.
Smart Hybrid Connect -flashing red lights - Page 2 - The EE Community
 Have you Check service status having given your post code there on the Network Status Checker and reported your problem via that link?
Thanks both
We’ve taken the sim out and tried re-starting both router and hybrid. The router is purple and theres a service status saying theres problems but not expected to be fixed until 8th.
The hybrid is still aqua but 3 red flashing bars.
Broadband went off about 2pm yesterday and both worked for about an hour this afternoon until they both went down again.
I might have to ring up tomorrow as the EE chat facility doesnt suggest anything.
