All our brilliant teams are based in the UK or Ireland.
Calling from EE mobile 150
Free to pay monthly
25p per call on pay as you go
Calling from EE landline
0800 079 8586
From another provider
0800 956 6000
25-01-2023 01:32 PM
Hello,
It’s been 3 days now that I’m sitting without the broadband working at all, it’s just blinking yellow.
The power is green and the wireless but there’s no internet at all.
This is an ee bright box.
I have tried restarting resetting checking lines and everything but it is still not working.
25-01-2023 01:36 PM
What does it say after you log into the router:
Obscure your names & any digits in the BB Username but post the 1st 2 parts of the (Broadband) IP address. This might tell us at which stage EE have got to.
Does the landline phone work? Do you get a dial tone? Does it announce your correct no. when you dial 1470 17070?
25-01-2023 01:43 PM
Hello,
I cannot login into the router at all because there’s no internet, it’s just blinking.
I am using mobile data and tried to login but the page isn’t loading up.
25-01-2023 02:35 PM
You don't need the Net to be able to login to routers. In fact you can do so even when they are unconnected to the phone socket.
25-01-2023 02:47 PM
@Ha48 have you spoken to the Broadband Care Team? Option 3
Free to pay monthly
0800 079 8586
0800 956 6000
25-01-2023 03:57 PM
Hello,
I have managed to login and it says as follows:
broadband type: ADSL
Broadband state: disconnected
Internet state: disconnected
Time connected: 00:00:00
Downstream Rate: 0 Mbps
Upstream Rate: 0 Mbps
IP Address: 0.0.0.0
Broadband Username: xxxxxxxxx
25-01-2023 03:58 PM
Hello,
I have not called but I will be doing it first thing tomorrow morning, thank you.
25-01-2023 04:00 PM
25-01-2023 04:00 PM
Yes, no BB there at all.
If it is a neighbourhood issue, you could consult BT Service Status to see if any faults are being attended to in your local area.
25-01-2023 04:03 PM
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
