on 22-05-2026 06:48 AM
I have no access to the internet. The light is orange and I switched off and on but still not working
Solved! Go to Solution.
on 22-05-2026 06:50 AM
If it is a neighbourhood issue, you could consult Check service in your area to see if any faults are being attended to in your local area. You may also Report a Problem there.
Have you reported your problem with your BB to EE? They can't do anything about it until you do. Text HELP to 66033 to get EE to test the line & see what needs doing.
What is the name of the EE BB plan are you on including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
