Broad band insulation
ClarkOliver86
Hi my broadband was ment to be getting installed today and there is no sign of bt
Maestro
Maestro
@ClarkOliver86 EE CS should be able to tell you tomorrow at the earliest to what has gone on with the no show for the install, you did reply to the OR text's on your mobile as they were received... Will also be able to reschedule another appointment.
