Bb sign in
Shelly0405
Does anyone know how to change the broadband password?
@Shelly0405  Password to login to the WiFi connection?    You do that by Simon to the router as admin.   You’ll find the IP address that you enter in to a web browser and the password to gain access on the router in order for you to do this.  It should be on a printed sticker on the back of the router
Brilliant Contributor
@Shelly0405 If you log into the router with a web browser 192.168.1.254, select wireless settings, change, enter admin password, this will allow the wireless password to be changed. If you wish to change the router password it is similar, but go to advanced settings, there you will find the admin password this allows this password to be changed.
Mustrum
@Shelly0405  There are details of how to change the WiFi password in the sticky thread at the top of this forum section.
https://community.ee.co.uk/t5/Broadband-Landline/Changing-Your-WiFi-Password-on-a-Smart-Hub/td-p/829...
Which BB pwd? On which router?
Login to your EE SH/SR at http://192.168.1.254 with the admin password on the bottom of the slider label on the back of the router. Then on the Advanced > Advanced WiFi page you should be able to see your WiFi password in clear & change it if you like.
