27-10-2026 05:34 PM
I ordered the battery backup unit (BBU) to power the ONT and EE Smart Hub Pro.
Problem is that it powers the ONT, but as soon as I plug in the Smart Hub it flashes red and shuts down power to both.
My Hub is the Smart Hub Pro 7. Anyone know if this is supported?
Wait time for support is currently over one hour.
01-11-2026 05:25 PM
Yes. And OK with ONT. The code says it’s an error with the device it is connecting to. I’ll speak to ER tomorrow as given up on hold and chat for today.
01-11-2026 05:44 PM
@GDog3 I was updating the reply but you got in first so see the message above about looking at the two plugs, compare the PSU one to the BBU one, they should look identical physically, but have never seen so not sure what the centre pin looks like, If cable is wired wrong there is nothing you can do, are you an Engineer per chance although checking that cable is fairly straight forward does need to be done disconnected with a meter on resistance.
02-11-2026 05:14 PM
Hi Jim
This is getting rather amusing...
I spent a long time on chat with EE today. They initially advised I open the case, remove the batteries, reseat them a bit and try again 😂
Eventually they decided that they need to send an engineer to me to plug it in.
In the meantime, here are the two plugs. Black one from the BBU, white from the PS to the hub.
02-11-2026 05:51 PM - edited 02-11-2026 06:01 PM
@GDog3 Look carefully down the centre off the plugs, you should see a pin on both right in the middle cannot be seen from your pictures, see if the BBU cable has the pin pushed over to the side and not straight, your PSU cable is working just fine or the 7 Pro would not be powering up...
Both the plugs look to be physically the same size, but they are THREE pin types so the EE document say's, but if the cable is wired wrong for the BBU one then there is nothing at all you can do, see the link below for the E5 error code. EXCESIVE current drawn from the BBU so it is protecting itself and possibly the 7 Pro hub if it is wired wrong.....
It's not an easy plug/cable to check unless you have the Equipment to do so.
https://www.bt.com/help/home-phone/fix-a-problem/problems-with-battery-back-up
02-11-2026 06:05 PM
I strongly suspect that the cable they have sent is wrong. They didn't send a new cable with the new BBU.
Let's see what the engineer says - when he has finished swearing for being sent out... LOL
Due on Saturday.
02-11-2026 06:15 PM - edited 02-11-2026 06:42 PM
@GDog3 There is only one specific cable for the 7 Pro hub, so it does look like the correct one especially as it has the white ring on both, but it does not say if it was wired up correctly, not sure if the block where the dual cables exit the single one with the yellow that goes to the back of the BBU is were they terminate and get soldered up, but leave it to the Engineer to look at, he/she may have seen it all before, and just a real pity they never sent a new cable as well.🙄
If you get the chance take a picture bottom of the Pro Hub socket were the cable plugs into.
From earlier in the post below is the cable part number, the EE Pictures in the store are wrong but the BT video does have the BT Smart Hub 2 as a Plug with a black ring end of the cable so do not suspect they gave the wrong on, see if you have any labels about that match below info.
EE Smart Hub 7 Pro
Compatibility EE Smart Hub Pro (SH40J)
Manufacturer Part Number 5061061580042BBU
EE Article Code 400023338
07-11-2026 12:42 PM
Hi again
Earth pin bent in the power supply cable for the router.
Trying to get a new one...
07-11-2026 12:55 PM
@GDog3 Was it your spot or did the Engineer visit and do the stamp feet war dance around it all. Sometimes you can fish and get the pin up and semi straight but takes patience and good eyesight, 1st i have 2nd is a no-no.
07-11-2026 12:57 PM
He spotted it - My eyesight not so sharp these days. He tried a wiggle but decided it was too bent to be safe.
I'm now waiting on a call from BT (!?) so I can order a replacement. Not sure why they don't just send one, and why they didn't in the first place when they replaced the BBU <sigh>
07-11-2026 01:01 PM - edited 07-11-2026 01:08 PM
@GDog3 Can happen, might even have been that way from when it was all made at the manufacturing stage, everything was out off stock when i looked last week, hopefully they find and send out more waiting about no doubt.... At least you have a couple off BBU's now so you can test with both. 3 way plug that one, centre and outer are both the 0V connection, but would be safer to get a new connector as if was all wired connect possible breaking off the centre one may work that would also not be easy to do, getting it back up and squarish also not easy....
