27-10-2026 05:34 PM
I ordered the battery backup unit (BBU) to power the ONT and EE Smart Hub Pro.
Problem is that it powers the ONT, but as soon as I plug in the Smart Hub it flashes red and shuts down power to both.
My Hub is the Smart Hub Pro 7. Anyone know if this is supported?
Wait time for support is currently over one hour.
29-10-2026 10:16 PM
I'm not sure what the issue is that you are trying to resolve here, but if it is the size of the plugs then I can confirm that the BT Smart Hub 2 is 3.0 mm x 5.5 mm. 3.0 mm is an unusual size. More of an American thing, I think.
Incidentally, you can use a set of metric drill bits as gauges to measure the internal diameter. If a 3.0 mm doesn't fit try a 2.5 mm. If that doesn't fit but a 2.0 mm does then it will be a 2.1 mm etc.
29-10-2026 11:28 PM
@Denzel99 Special 3 pin connector barrel socket on the EE Smart Hub 7 Pro version, with 2 GND connections and 1 +12V D.C. centre and outer are Gnd's with the inner part off the round barrel having the positive on it, never seen on but would be very hard to check without getting a socket plugged on it for pin access.
30-10-2026 06:47 AM
Hello Denzel
The issue is outlined in my original question.
Best wishes
G
30-10-2026 02:27 PM
@JimM11 Centre positive is fairly normal. If it’s the pin diameter, you can find a plug that fits it and then measure the hole in that plug and deduce the pin diameter etc.
@GDog3 Fair enough. I was just going by the plug in the picture. As I said, I wasn’t sure what you were after. Sorry I couldn’t help.
30-10-2026 02:45 PM - edited 30-10-2026 02:46 PM
30-10-2026 10:07 PM
@JimM11 Yes, I see what you mean. That is a peculiar design.
31-10-2026 02:33 PM
I'm beginning to suspect they were out of stock and sent what they had, as the replacement still hasn't been shipped...
31-10-2026 05:05 PM
@GDog3 Could be the case, also may be waiting on a returned unit to send to you also, do you know if getting both again the BBU and the 7Pro cable set? Trouble is it's working connected to the ONT but the power is just so low on that unit would last forever time wise protecting that alone, the 7 Pro hub is a way different animal pulling a few amps out of the BBU, but as you have said as soon as that is connected on it's own the BBU shut's down, thinking it is either protecting itself from current draw, or maybe the batteries in the BBU are goosed.
You could do the BBU on the ONT by itself, once fully charged pull the mains cable off it and see how long it runs.
01-11-2026 04:27 PM
This is getting interesting...
New BBU arrived but without cable. A different model number...
Connected up and this one now reports E5 which suggests it doesn't like the hub.
01-11-2026 05:17 PM - edited 01-11-2026 05:36 PM
@GDog3 Is the E5 in the display for the unit? and does it look ok when connected to the ONT for operation.
Would assume E5 is an error code to display, any manual or paper document with it, the vodafone unit is the same BBU but unfortunately no document on there site either to say what E5 is. Found the linked info BT site.... LOOK very carefully at the BBU splitter cable for the Pro connection, you should i think see a cable pin bang centre off the plug and make sure it looks that way and is not pushed away to the side..... If the cable is wired wrong you may get a HUGE current draw for wrong polarity also.
