on 29-04-2024 02:34 PM
When changing from BT full fibre broadband to EE the engineer left the ee hybrid provided by BT connected. Do we still need this?
Solved! Go to Solution.
on 29-04-2024 04:54 PM
@Beyond1 Older model of the hybrid connect. Link above will show you the new model. Below pulled from the BT website, does any of it apply or work please read.
Colour/ Shape
What it means
Solid green circle | Your device is starting up. |
Flashing green circle | Your device is not paired to your hub. Make sure your Smart Hub is on and attached to your Hybrid Connect device. |
Solid blue circle | Your device is paired with your hub. |
Flashing blue circle | Your device is pairing with the hub. |
Solid orange circle | Your device is too far from the hub. |
Solid red circle | There's a problem. Restart your device, and if the light is still red get in touch. |
Flashing red circle | Your device cannot connect. Try moving Hybrid Connect. If you still cannot connect to the mobile network, contact us. |
Solid white circle | Firmware update required. Disconnect the Hybrid Connect from the Hub, then perform a Factory Reset on the Hybrid Connect by pressing the pinhole reset button on the back for 15 seconds. Once the circle starts flashing green, connect the Hybrid Connect to the Hub via Ethernet and then leave for 30 minutes to set up. |
Solid blue bars | Your device has a strong mobile signal (two or three bars are good). |
Flashing blue bars | Your device is connecting to the mobile network. |
Partially blue bars | Your mobile signal is not strong. |
Solid white bars | Your device is using mobile data because your broadband is not working (two or three bars are good). |
Partially white bars | Your mobile signal is not strong. |
Solid red bars | There's a problem with your device. We'd like to help, so please get in touch. |
Flashing red bars | Your device cannot connect to the mobile network. |
on 29-04-2024 03:00 PM
When changing from BT full fibre to EE the engineer left the EE hybrid, which came with BT, connected . He wasn't sure whether it was needed but left it anyway. Do I need this?
29-04-2024 03:05 PM - edited 29-04-2024 03:31 PM
@Beyond1 Do you have that add-on as part of your EE broadband package, if so then yes you need it, will allow you to fall back to 4G broadband if your fibre network goes down. If it is not in your package then in theory it should not work.
You may want to post a picture again as there are various units from EE so we know which one you have and if it works with your new EE broadband router!
on 29-04-2024 04:15 PM
this is it
on 29-04-2024 04:26 PM
@Beyond1 Waiting on your picture to clear. When you went from BT to EE, did your installer not setup all of the equipment and test all the functionality? Like your booster, yes you may have to move it can happen as units are not (apple to apple) by comparison, your 4G backup, really should have pulled the network fibre connection and waited to see that the 4G signal kicked in and you still had a minimal broadband at least. Hope at least your happy with your new connection? Will watch for picture to clear....
Colour/ Shape
What it means
