Address not listed even though "connected"
Matty831
Hi. So I want to join EE Fibre Broadband.
I live in a smal block of 4 flats. All are "connected" with BT phone line. And one of the flats is a BT Broadband customer. That flat is the only address listed to get EE fibre but not mine. How do i get my flat number to show on the address checker like the  flat above me so I can join?
Not currently an EE customer and they are not the easiest to contact
Thank you
13 REPLIES 13
@Matty831 wrote:
Are the flat numbers recognised on the BTW checker?
Yeah. All flats are recognised on there.
You said earlier yours wasn't!
Mustrum
@Matty831    OK the BTW address check confirms the landlord has registered the flats on the RM database.
So, as mentioned, pick a supplier, order a service, wait for the survey and for your new service to be installed. But do call, I have no issue with Sky, but would not trust the info they have - it needs an Openreach survey to progress, which your chosen ISP will arrange then confirm what they can deliver.
Matty831
@XRaySpeX
No I didn't.  I said BT/EE didn't recognise the address. But it is recognised in that BTW link @Mustrum  said to use.
@Mustrum thank you for the advice.
Also, I just put my postcode in the openreach website  and all flats are listed.
You answered in response to @Mustrum 's suggestion "You could try the address check option on the same form."
@Matty831 wrote:
Thank you. It says "We cannot determine broadband availability at this location. This may be a new address to which connectivity is not yet complete."
You also showed the result of your neighbour's addy at the same site.
Forgive me if I can't follow which Qs you think you are answering & that you are just repeating what you said in your OP.
