2 week review of EE 1.6gbs
Bluenose_Dave
Having been on the new 1.6gb/s service now for 2 weeks, and here are my views,
i have the EE new smart router plus and 3 extenders, first off i know the EE smart hub plus only has 1gb LAN ports, speeds have been ok and stable WIFI rangers from about 650-820  what is not bad, i m running with them hardwired with a lan to them, i know WiFi 6 max speeds are 1200 but rarely get them in the real world
this package feels like it been rushed out, my reason for saying this are,  openreach engineers laptops have 1gb Ethernet ports so they are unable to check speeds from ONT or any other Speedtest at your home if you are on the 1.6gbs package
the EE router having only 1gb LAN, also it comes with a cat 5e cable, this cat of cable does up to 1gb, so if you are on 1.6gb/s you will need to get a new Ethernet lead to connected the smart hub plus to the ONT
all the WiFi features like work and game mode and WiFi controls dont work, it say page not found, i have heard that the WiFi enhanced feature has been turn off so the team can look at it and fix it as it affecting a lot of users and should be back after a month, i am unable to check speed via the router page this time it asking for me to make an EE account
speeds and connection has been stable and good, but i did have a lot of issues getting the service
i know of people who have bought a 3rd party router so they can get full access to the raw 1.6gbs speeds, and they are having no issues on speeds as router has 2.5gb LAN on them unlike the EE smart hub plus
i have bought a usbc to 2.5gb Ethernet adapter so i can test the raw speeds at the ONT, plus if openreach do need to test speeds at my home they will be able too
so in short i hope you can see why i think this package has been rushed out from the fact openreach dont have the kit to test speeds at the customer home, to all the issues with the new smart hub plus
FFTP Busiest Home Bundle 1.6Gb,
Smart hub Pro and 3 backhauled smart WiFi Pro extenders
WiFi 7 devices iPhone 16 Pro Max
641 REPLIES 641
Bluenose_Dave
I have found they sent 48 hours but I got my last 2 routers last week the next day
gmbuspunk
@Bluenose_Dave ive noticed that tend to send them friday and turn up saturday maybe it because rm dont wotrk sunday so speed them up
FFTP Busiest Home Bundle 1.6Gb Hopefully we get the wifi 7 router before christmas 2024
Part of the wifi 7 (smart Hub Pro gang)
Finnaly got the smart hub pro thursday 10 th october 2024
Just in time for christmas 2024 >69 days or less until cristmas
Merry christmas and Happy New year/Hogmany for 2025 may the auld lang syne ring out when it comes have to get round everyone by new year hope you had a good one now march 2025 is here
timprocter
Just come off the phone to the next gen team regarding this new router.
Thanks for the number @Bluenose_Dave ............. Mine will be here next week with a WiFi extender to match they confirmed.
I asked if I had to send the original Smart Hub 2 back and was told keep it for a spare. Happy days.😁
Full Fibre Busiest Home Bundle 1.6Gb.
Bluenose_Dave
Nice one Tim. Finally a router fit for the connection from EE
gmbuspunk
It should be brilliant when we finnally get it 😄
garetc
Scholarly Contributor
Having some building work on the house done this week so I flipped over to the EE Wi-Fi 6 router so my own doesn't get plaster all over it.
Genuinely forgotten how bad their router is, it's impossible to use and woefully under specced for the connection.
  • One room away from the main router I'm getting 60Mbps down compared to my usual 800 on Wi-Fi 6 (1070Mbps on Wi-Fi 7).
  • One floor away from the router I have a satellite, getting 64Mbps on a PC hardwired into it (Usually get around 1400Mbps on my own setup).
  • The TV in the lounge has line of sight to the router and is WiFi 6 but keeps buffering so bad Netflix is impossible to watch so I am tethering off my phone.
Their new system has to be better than this.
Bluenose_Dave
You would hope it is not as bad as smart hub plus is
Brilliant Contributor
@garetc Don't think much would ever beat your ORBI.
garetc
True but the spec of the new EE router is good compared to the ORBI (and doesn't cost £2199).
 I think it'll give the ORBI a run for it's money..
 Orbi EE
6GHz4x4/320MHz, 4K-QAM320Mhz 4×4
5GHz4x4/240MHx, 4K-QAM (dedicated wireless backhaul only)Not available
5GHz4x4/160MHz, 4K-QAM160Mhz 4×4
2.4GHz4x4/40MHz, 1K-QAM40Mhz 4×4
Processor
Quad-core 2.2GHz processor
Qualcomm Bells IPQ9570
Quad Core 2.2Ghz
Memory 4GB Flash and 2GB RAMFlash 8GB
RAM 2GB
Antenna
Twelve (12) high-performance internal antennas with high-power amplifiers
Not available
PortsOne (1) 10 Gig Internet WAN port
One (1) 10Gbps Ethernet LAN port
Four (4) 10/100/1000/2500Mbps Multi-Gig Ethernet LAN ports
1 x 2.5Gbps WAN (Ethernet)
4 x 2.5Gbps LAN (Ethernet)
@garetc At the cost ratio of 9:1, even if it's just a little bit slower, as i said, the bargain of the century to be had from EE!
Give it a good going over when you do.
