Don't run out of charge! Helpful tips to keep your phone powered up
TiffJ
Former EE Community Manager
Don’t count the hours ‘til your phone is drained. Have an extra battery bar on us with these tips on keeping powered up.
Start simple
It’s important to power down before powering back up.  For example, if your device is feeling warm, let it acclimatise to indoor temperature. Keep the room cool to recharge faster.
If possible, turn your phone off whilst it’s charging. Turning the screen off is a second-best solution if you just can’t do without your notifications.
Tinkering around in your phone’s settings can provide unexpected longevity. Disable dormant apps or select low power whilst you’re still in the green. You’ll thank yourself on the long walk home.
Get equipped
There are so many ways to keep yourself well stocked on phone power. This range of on-the-go charging options will take you from bag to office to gym, guaranteed to keep you going all day.
Charging Pad
Charge your phone without a cable with this forward thinking charging technology, compatible with most QI enabled phones. Pop your phone down on the pad, stick the kettle on and come back when you’re ready to leave. Simple.
Power pads with EE>
Power bank
Keep not one but two (or more) of your devices alive and kicking with a power bank. Small enough to fit discreetly in most size bags, these coaster shape boxes pack a strong punch, so no more running out of battery on the long walk home.
See what power options EE has for you in our online store>
Fast charging travel adaptor
You didn’t go on holiday to panic. Stick this fast charging travel adaptor in your hand luggage for those last minute check in emergencies and watch as your phone powers up at double the regular speed, regardless of voltage.
The smart choice for smartphones
Getting a new smartphone and want one that keeps its charge for a long time? Check out our list of smartphones with the best battery life>
Tips for keeping powered up come in all shapes and sizes, and we’d love you to share yours below.
10 Comments
Profile closed
Not applicable
Retricting data usage from app's  running in the background you can restrict anything you want, but REMEMBER not to restrict messaging, playstore, android manager, or the download app, because this may cause problems!
for the device you're using!
Restricting certain app's running in the background does "save data" and at the same time, it also help's extend the device's battery life too.
This is just an example of what can be achieved!  Over a 16 hour period my mobile used just 1 single mega-byte. You might think this is impossible!
No, it is not! so,
You too can benefit from making some simple ajustments!
Regards:
Robert ☺
Ben090
Great comments @Profile closed.
Profile closed
Not applicable
 Hi, Ben090,
Thank you for you're welcome support, much appreciated! ☺
Regards:
Robert ☺
Profile closed
Not applicable
Hi, Leanne_T,
Thank you too, for giving me a big "thumbs-up!"
Much appreciated! ☺
Regards:
Robert ☺
Richard_C
Maestro
Maestro
I shall pass this on to @Leanne_T
Thanks again @Profile closed
Richard
Profile closed
Not applicable
Hi, Richard_C, please do my friend,
And thank you for you're support as well!
Much appreciated! ☺
Kind tegards:
Robert ☺
Richard_C
Maestro
Maestro
No problem @Profile closed
Richard
Profile closed
Not applicable
NEW POST!
hey guys! How long has that been there?
Being able to upload photo's, files and even copy & paste URL's.. That's brilliant!!
Don't say it was always there or i'm gonna need to visit "specsavers" lol 😂
       HAPPY DAYS
           Everybody!
Regards:
Robert ☺
James_B
That feature has just been activated today @Profile closed
Glad you like it! Smiley Happy
Profile closed
Not applicable
Hi, James_B,
Thank you for confiming that,
Now I won't need to visit "specsavers" after all ☺
Like it? lol I love it 😘💕
Kind regards:
Robert
