close
problems connecting Efergy Engage Hub to 4gEE router
kbjpick
Hi
Had above energy monitoring Hub working on EE Landline router but as router had c 6 Mbit/s throughput I added a Mobile 4GEE router which gives 30-50 Mbit/s performance - Yay, BUT, when I try to connect Engage Hub it will not connect with Efergy's servers!
Any ideas? TIA
10 REPLIES 10
You probably need to switch the mobile router to the 2.4 GHz WiFi band. These smart home devices often can't do 5 GHz.
Thanks for that - but how do you direct ethernet socket to use only 2.4 Ghz Wifi band? The Admin panel for the router doesn't even identify number of wired connections to 4GEE router, let alone allow you to specify which band that Ethernet socket is to use? Or am I missing something?
@kbjpick : Do you have the heating hub connected to the router by Ethernet? In which case my advice above doesn't apply. I thought it would be by WiFi.
Which model router do you have?
kbjpick
Thank you for continued interest - Router is 4GEE device
*Device name: **4GEE Router*
*IMEI: **xxxxxxxxxxxxxxx*
*Software version: **HH70_E1_02.00_24*
*Modem version: **HH70_E1_02.00_24*
*MAC address: **xx:xx:xx:xx:xx:xx*
kind regards
[mod edit: please do not post personal information on the public board. Thanks!]
@kbjpick : The other poster was talking about a completely diff router on a diff network. His issue is not your issue. I've separated them!
Great, I am now so confused - apologies if I messed things up.
Tried to work out where to find posts but no luck... will try again later.
Sent from Yahoo Mail for iPad
Click on your nick to L of any post & you'll see all your posts.
It wasn't you confusing things. It was other poster latching onto your thread with an entirely diff issue.
Your comment "Click on your nick to L of any post & you'll see all your posts." means absolutely nothing to me - would you please elaborate in plain English?
Katie_J
Hi @kjpick.
If you click your username this should show your posts.
Katie.
