24-02-2021 03:21 PM
Is there any way to escalate an issue with the repair team if you know their appraisal is wrong. If someone can explain how this is damaged I will be super grateful.
24-02-2021 04:31 PM
Hi @Blackline72
Is this a photo that was provided by the repair team? Is this the side of the iPad?
24-02-2021 04:35 PM
What are you saying is damaged here? Maybe after you put it in bulldog clips you have damaged the screen but that won't be covered under warranty.
Also damage isn't covered anyway.
24-02-2021 04:56 PM
This is the picture the repair centre provided. I believe it’s the side.
24-02-2021 04:58 PM
Hi. This is the picture the repair centre provided. Also I’m not terribly happy they used bulldog clips on a £1000 plus price of equipment.
24-02-2021 04:59 PM
It’s meant to be the side I believe. This iPad doesn’t leave my desk so I’m baffled by their diagnostic.
24-02-2021 05:00 PM
@Blackline72 On the image provided it says back housing damage but they are showing a picture of the side ? Where’s the damage.
24-02-2021 05:03 PM
This is what I’m trying to work out. I can’t see any damage at all. I think they are trying to pull a fast one but EE has never been a problem before.
24-02-2021 05:18 PM
There is no damage that I can see on there.
I'd question them why they are holding it with bulldog clips. Pads on it or not. That is not acceptable.
Issue is this isn't EE they use Brightstar I believe.
Personally I would ask for it back and send it to Apple direct.
24-02-2021 05:24 PM
