on 29-11-2018 01:36 PM
I upgraded my on Monday 26th online got my order code and confirmation Email 3 days later still no word if it's been dispatched or anything when I try to track it just wondering if this is normal.
on 29-11-2018 04:24 PM
Good Afternoon @Fletchv1.
What phone did you upgrade to?
Have you tried tracking this using the online tracker?, All you need is your order reference number which is at the top of your confirmation email.
If you can take a look and let me know what it says.
Speak soon, Katie 🙂
on 29-11-2018 05:43 PM
Hi I upgraded to a Samsung galaxy S9 and I have tried to use the online tracker but there is no info to give other then I will be emailed or texted with updates.
on 29-11-2018 05:49 PM
Thank you for checking this @Fletchv1.
I would recommend giving our customer service team a call who can check the progress of your order for you.
Hopefully it's not much longer for you.
Katie 🙂
on 07-12-2018 12:53 PM
Any luck? I have the same problem
