close
TivkTalk 4 watch
Angel1975
Hi to EE offer a GSM sim? I've purchased  Ticktalk4 kids watch and need a sim that includes data, text and calls. Thanks
All SIMs are capable of all the 'G's. They just "downgrade" to the capability of the device they are in.
Be aware that GSM (2G) is likely to be phased out in UK by 2026.
Thank you very much thats appreciated so GSM is any 2g sim? I wanted to know if EE support such sims for the ticktalk 4 watch?
Christopher_G
Hi @Angel1975
We can supply you with a SIM card that is 2G compatible that will pop out into three sizes (normal size, Micro and Nano). We cannot guarantee it will work with your device, you would have to check with the watch manufacturer.
Order an EE SIM card >
Can someone on EE please check if I can get a sim for my ticktalk4 watch. Its seemingly 4G, but it needs to be GSM?! I bought this watch from USA for a christmas gift.
Thanks so much
@Angel1975 : You've already had an answer, which was Yes.
