close
Reinstate discontinued number
Treth
How can I start using a number I haven't used for months, that seems to have expired? If I dial it from another phone i get "Calls no longer being connected to this number", so it doesn't seem to have been re-allocated.
Northerner
Hi @Treth
Please read EE hibernation policy which explains the process.
https://community.ee.co.uk/t5/Pay-as-you-go/What-is-pay-as-you-go-and-flex-hibernation-and-how-do-I-...
It maybe your number is now cancelled depending on when you last made a chargeable call or text.
@Treth : Sounds like it has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
