close
Personal Hotspot throguh iPhone
Peterpea
Hi, sorry if this has been asked before but i'm having issues working from home with my homebroadband (Sky) i work in a call centre usually so we have phones on our PCs that run through the internet but for some reason this time round the set up of the phones to make them stable means they run a way that is incomptable with Sky's fibre. i'm locked in a contract with them for another 12 months so i cant change suppliers.
the phones do work perfectly if i use the 5G hotspot option with my iPhone 12 Pro and i have unlimited data. does anyone know if there are limits on hotspots? dont think my PC will use much data - it only used 5 gb in the last week but dont want any nasty surprises on my bill
@Peterpea   There is no limit.   But I will inform you your unlimited tariff is actually only 600Gb per month.
