Panasonic wireless phone KX-TGE722E. With answering system.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-01-2021 10:56 AM
I would like to know how to adjust the number of rings before 1571 answers, the problem I have is 1571 is answering before the device system, I would like to increase the number of rings for 1571 and decrease the number of rings on the system device. The operating booklet contact the service provider to change the number of rings for 1571 or voicemail.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-01-2021 12:21 PM
1Mikeo.. This is a function of the phone. I have a Panasonic model similar (though not the same) as yours. With mine you can increase the number of rings from 2 up to 7, the auto setting is 4. This is done on mine as follows..
Settings/Answer System - OK/Settings - OK/Number of rings - OK/select number with up/down keys/OK
Hope that helps.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
18-01-2021 07:54 AM
I need the answering system to answer before the voicemail, I will have to call EE technical (my provider).
Again many thanks.
1mikeo
Sent from Mail for Windows 10
