Open tablet
Sb1258
Hi I can't remember my pattern on my tablet does anyone know how to bypass it so I can get to use my tablet
BrendonH
Community Hero
Community Hero
If you forgot your pattern you should have set a back up password or pin.
Of you forgot this too. Then the o my way is to preform a factory reset which will erase all your data
BrendonH (Android Expert) Google Pixel 8 Pro Obsidian Black (Android 15)
