08-03-2021 06:04 PM
Does the device mot fix a volume button which has become unresponsive?
08-03-2021 07:15 PM
@MarcAli The device has a warranty on it but depending on how it’s broken will depend if it’s covered under warranty.
09-03-2021 08:00 AM
Hi @MarcAli
Welcome to the community.
Has the button been damaged or just stopped working?
Do you have a case covering the volume button?
Thanks 🙂
09-03-2021 02:35 PM
The handset is in pristine condition and is coming up for two yrs old in June, so will be upgrading then, but a few months without those buttons working is a prob
09-03-2021 02:37 PM
Thanks @MarcAli
If you use our online troubleshooting tool, this will run through some diagnostics with you and let you know your next steps for a repair if this is needed 🙂
Or, you can give us a call on 150 and our Tech Gurus will get this looked into for you.
