close
High ping and 50% packet loss
blipblop
Valued Contributor
Valued Contributor
as the title says, my ping today is between 60 and 300ms typically, whereas it's usually 20ms or less to google.co.uk.
There are no other networked devices using any bandwidth when i run the tests.
Screenshot attached.
Thanks, Gary.
Christopher_G
Hi @blipblop
Welcome to the community.
Has this caused any problems with any of the devices that you're using? Is it any better this morning?
Thanks Chris, it turned out to be a homeplug problem.
Leanne_T
Thanks for coming back and letting us know @blipblop
