Forced into recovery mode
docdid
I have an iPhone 12 Pro and wifi calling just never works since switching from Vodafone. Spoke with tech support who made some changes, after a while I was sent a text and asked to restart. The restart left the phone recovery mode which was a problem as I am on call, managed to restore while at a friends house but it meant loss of service for about 2 hours.
is this a recognised occurrence? should I chase EE for an explanation?
Plus is wifi calling an issue for others?
Northerner
Hi @docdid
WiFi calling only works when you have no signal. Do you receive a mobile signal without WiFi calling?
Are you on PAYG or pay monthly contract?
All calls fail, incoming and outgoing when no 4g - wifi simply does not work.
Pay monthly
Schockwave
@docdid , Have you gone into settings, mobile data and checked that wifi calling is on? You may need to have a network refresh.
When you have 4G signal showing, are you able to make outgoing calls and receive incoming calls at all? Is the problem just happening in one place or everywhere?
@docdid   What EE did will not force your device in to recovery mode.  What EE did was probably reset your line.  Is it working now ok ?  If not try a network reset on your device you’ll have to put your WiFi passwords back on your device after this.
X
LinkedIn
Facebook
YouTube
