09-12-2020 03:28 PM
Anybody else had a Firmware upgrade dated 5-12-20
EE Smarthub
Firmware updated: 5-Dec-2020 Firmware version:v0.06.01.08190-EE
Previously =Downstream sync speed: 29.56Mbps Actual download speed 25-26Mbps
After Firmware downgrade.
Downstream sync speed: 25.00Mbps Actual download speed 19/20Mbps
Where has my speed gone ...why have you stolen it EE.
09-12-2020 05:26 PM
@MrAngree Have you tried restarting the router? Turn it off for 30+ seconds then restart it and test.
09-12-2020 06:12 PM
yes restarted from inside the hub manager....
waiting to see if loads of other people affected..
previously the hub has restarted automatically and given me a speed of 19mbs...This obviously not good enough rebooted the hub and got 25mbs back....dont know why they mess with it so much.........Previous isps speed the same every test this seems a random . Like a game of roulette you wonder what speed you are going to get when you test it.
I will try another reboot and see if im lucky.......
09-12-2020 07:03 PM
09-12-2020 09:04 PM
well that looks like a message from a robot.
I have already stated the facts.
EE have changed something their end.
New Firmware...SLoooooWer Internet speeds nothing else to sort.
10-12-2020 10:57 AM
07:35:59, 10 Dec. admin login success from 192.168.1.216 07:18:35, 10 Dec. admin timeout from 192.168.1.216 07:09:50, 10 Dec. DHCP device Connected: 192.168.1.216, ec:8e:b5:d9:52:48, heinzypantzy-510-p199na 07:09:49, 10 Dec. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 07:09:49, 10 Dec. A device connected to Ethernet port 1 07:09:49, 10 Dec. Wire Lan Port 1 up, Speed 1000 Mbps 07:09:49, 10 Dec. Receive a DHCP request 07:08:42, 10 Dec. A device disconnected from Ethernet port 1 07:08:42, 10 Dec. Wire Lan Port 1 down, Speed 10 Mbps 07:08:30, 10 Dec. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 07:08:14, 10 Dec. A device connected to Ethernet port 1 07:08:14, 10 Dec. Wire Lan Port 1 up, Speed 1000 Mbps 06:46:39, 10 Dec. CWMP: HDM socket closed successfully. 06:46:39, 10 Dec. CWMP: HDM socket opened successfully. 06:46:39, 10 Dec. CWMP: Set Parameter by TR069 Success. 06:46:38, 10 Dec. CWMP: HDM socket closed successfully. 06:46:38, 10 Dec. CWMP: HDM socket opened successfully. 06:46:38, 10 Dec. CWMP: session completed successfully 06:46:38, 10 Dec. CWMP: HDM socket closed successfully. 06:46:37, 10 Dec. CWMP: HDM socket opened successfully. 06:46:37, 10 Dec. CWMP: Server URL: https://ee.x.x; Connecting as user: ACS username 06:46:37, 10 Dec. CWMP: Session start now, server: https://ee.x.x, Event code: 06:46:37, 10 Dec. CWMP: Initializing transaction for event code 2 PERIODIC 06:45:44, 10 Dec. CWMP: HDM socket closed successfully. 06:45:44, 10 Dec. CWMP: HDM socket opened successfully. 06:45:44, 10 Dec. CWMP: Set Parameter by TR069 Success. 06:45:43, 10 Dec. CWMP: HDM socket closed successfully. 06:45:43, 10 Dec. CWMP: HDM socket opened successfully. 06:45:42, 10 Dec. CWMP: HDM socket closed successfully. 06:45:42, 10 Dec. CWMP: HDM socket opened successfully. 06:45:42, 10 Dec. CWMP: session completed successfully 06:45:42, 10 Dec. CWMP: HDM socket closed successfully. 06:45:37, 10 Dec. CWMP: HDM socket opened successfully. 06:45:37, 10 Dec. CWMP: Server URL: https://ee.x.x; Connecting as user: ACS username 06:45:37, 10 Dec. CWMP: Session start now, server: https://ee.x.x, Event code: 06:45:37, 10 Dec. CWMP: Initializing transaction for event code 2 PERIODIC 05:49:59, 10 Dec. 5G Client associate from 74:a7:ea:46:f0:c0 (IP=192.168.1.109) RSSI=-31, Rate=866Mbps, host amazon-ad228f167 05:49:58, 10 Dec. Receive a DHCP request 04:45:39, 10 Dec. CWMP: HDM socket closed successfully. 04:45:39, 10 Dec. CWMP: HDM socket opened successfully. 04:45:39, 10 Dec. CWMP: Set Parameter by TR069 Success. 04:45:38, 10 Dec. CWMP: HDM socket closed successfully. 04:45:38, 10 Dec. CWMP: HDM socket opened successfully. 04:45:37, 10 Dec. CWMP: HDM socket closed successfully. 04:45:37, 10 Dec. CWMP: HDM socket opened successfully. 04:45:37, 10 Dec. CWMP: session completed successfully 04:45:37, 10 Dec. CWMP: HDM socket closed successfully. 04:45:36, 10 Dec. CWMP: HDM socket opened successfully. 04:45:35, 10 Dec. CWMP: Server URL: https://ee.x.x; Connecting as user: ACS username 04:45:35, 10 Dec. CWMP: Session start now, server: https://ee.x.x, Event code: 04:45:35, 10 Dec. CWMP: Initializing transaction for event code 2 PERIODIC 02:45:36, 10 Dec. CWMP: HDM socket closed successfully. 02:45:36, 10 Dec. CWMP: HDM socket opened successfully. 02:45:36, 10 Dec. CWMP: Set Parameter by TR069 Success. 02:45:35, 10 Dec. CWMP: HDM socket closed successfully. 02:45:35, 10 Dec. CWMP: HDM socket opened successfully. 02:45:34, 10 Dec. CWMP: HDM socket closed successfully. 02:45:34, 10 Dec. CWMP: HDM socket opened successfully. 02:45:34, 10 Dec. CWMP: session completed successfully
10-12-2020 10:58 AM
02:45:34, 10 Dec. CWMP: HDM socket closed successfully. 02:45:33, 10 Dec. CWMP: HDM socket opened successfully. 02:45:33, 10 Dec. CWMP: Server URL: https://ee.x.x; Connecting as user: ACS username 02:45:33, 10 Dec. CWMP: Session start now, server: https://ee.x.x, Event code: 02:45:33, 10 Dec. CWMP: Initializing transaction for event code 2 PERIODIC 01:47:47, 10 Dec. DHCP device Disconnected: 192.168.1.216, ec:8e:b5:d9:52:48, heinzypantzy-510-p199na 01:47:46, 10 Dec. A device disconnected from Ethernet port 1 01:47:46, 10 Dec. Wire Lan Port 1 down, Speed 10 Mbps 00:59:32, 10 Dec. CWMP: HDM socket closed successfully. 00:59:32, 10 Dec. CWMP: HDM socket opened successfully. 00:59:32, 10 Dec. CWMP: session completed successfully 00:59:32, 10 Dec. CWMP: HDM socket closed successfully. 00:59:32, 10 Dec. CWMP: HDM socket opened successfully. 00:59:32, 10 Dec. CWMP: Server URL: https://ee.x.x; Connecting as user: ACS username 00:59:31, 10 Dec. CWMP: Session start now, server: https://ee.x.x, Event code: 00:59:31, 10 Dec. CWMP: Initializing transaction for event code 4 VALUE CHANGE 00:59:00, 10 Dec. PPP IPV6CP Send Configuration Request 00:58:57, 10 Dec. PPP IPV6CP Send Configuration Request 00:58:54, 10 Dec. PPP IPV6CP Send Configuration Request 00:58:50, 10 Dec. PPP IPV6CP Send Configuration Request 00:58:49, 10 Dec. NTP synchronization success 00:58:47, 10 Dec. PPP IPV6CP Send Configuration Request 00:58:44, 10 Dec. PPP IPV6CP Send Configuration Request 00:58:41, 10 Dec. PPP IPV6CP Send Configuration Request 00:58:39, 10 Dec. WAN Sensing Auto sensing Complete, interface selected 00:58:38, 10 Dec. PPP IPV6CP Send Configuration Request 00:58:37, 10 Dec. WAN DHCPv6 events: INIT 00:58:36, 10 Dec. NTP synchronization start 00:58:35, 10 Dec. PPP IPV6CP Send Configuration Request 00:58:33, 10 Dec. WAN Sensing Auto sensing Running 00:58:33, 10 Dec. Success - secondary DNS servers 00:58:33, 10 Dec. Success - primary DNS servers 00:58:33, 10 Dec. WAN connection WAN2_INTERNET_PTM connected 00:58:32, 10 Dec. PPP: IPCP up 00:58:32, 10 Dec. PPP IPCP Receive Configuration ACK 00:58:32, 10 Dec. PPP IPCP Send Configuration Request 00:58:32, 10 Dec. PPP IPCP Receive Configuration NAK 00:58:32, 10 Dec. PPP IPCP Send Configuration ACK 00:58:32, 10 Dec. PPP IPCP Receive Configuration Request 00:58:32, 10 Dec. PPP IPV6CP Send Configuration Request 00:58:32, 10 Dec. PPP IPCP Send Configuration Request 00:58:32, 10 Dec. PPP: CHAP authentication succeeded 00:58:32, 10 Dec. PPP CHAP Receive success : authentication successful 00:58:32, 10 Dec. PPP CHAP Receive Challenge 00:58:32, 10 Dec. PPP: LCP up 00:58:32, 10 Dec. PPP LCP Send Configuration ACK 00:58:32, 10 Dec. PPP LCP Receive Configuration Request 00:58:31, 10 Dec. PPP LCP Receive Configuration ACK 00:58:31, 10 Dec. PPP LCP Send Configuration Request 00:58:28, 10 Dec. PPP: Received PADS 00:58:28, 10 Dec. PPP: Sending PADR 00:58:28, 10 Dec. PPP: Received PADO 00:58:28, 10 Dec. PPP: Sending PADI 00:58:23, 10 Dec. PPP: Sending PADI 00:58:18, 10 Dec. PPP: Sending PADI 00:58:13, 10 Dec. PPP: Sending PADI 00:58:08, 10 Dec. PPP: Starting PPP daemon 00:58:07, 10 Dec. WAN Auto-sensing detected port DSL WAN 00:58:07, 10 Dec. DSL Link Up: Down Rate=24998kbps, Up Rate=6834kbps; SNR Margin Down=7.8dB, Up=6.0dB 00:57:35, 10 Dec. WAN Sensing Auto sensing Complete, interface selected
10-12-2020 10:58 AM
00:57:34, 10 Dec. WAN Sensing Auto sensing Running 00:57:33, 10 Dec. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER] 00:57:28, 10 Dec. PPP: Stopped PPP daemon(0,1,5) 00:57:24, 10 Dec. PPP LCP Send Termination Request (User request) 00:57:21, 10 Dec. PPP LCP Send Termination Request (User request) 00:57:21, 10 Dec. PPP: IPCP down 00:57:21, 10 Dec. PPP: LCP down 00:57:21, 10 Dec. DSL Link Down: duration was 24081 seconds 00:46:34, 10 Dec. CWMP: HDM socket closed successfully. 00:46:34, 10 Dec. CWMP: HDM socket opened successfully. 00:46:34, 10 Dec. CWMP: Set Parameter by TR069 Success. 00:46:33, 10 Dec. CWMP: HDM socket closed successfully. 00:46:33, 10 Dec. CWMP: HDM socket opened successfully. 00:46:32, 10 Dec. CWMP: HDM socket closed successfully. 00:46:32, 10 Dec. CWMP: HDM socket opened successfully. 00:46:32, 10 Dec. CWMP: session completed successfully 00:46:32, 10 Dec. CWMP: HDM socket closed successfully. 00:46:32, 10 Dec. CWMP: HDM socket opened successfully. 00:46:31, 10 Dec. CWMP: Server URL: https://ee.x.x; Connecting as user: ACS username 00:46:31, 10 Dec. CWMP: Session start now, server: https://ee.x.x, Event code: 00:46:31, 10 Dec. CWMP: Initializing transaction for event code 2 PERIODIC 23:27:05, 09 Dec. DHCP device Disconnected: 192.168.1.228, 88:ad:d2:d9:80:28, android-db919d0232c431c4 23:26:59, 09 Dec. 2.4G Client disassociate from 88:ad:d2:d9:80:28 (IP=192.168.1.228) RSSI=0, Rate=0Mbps 23:26:59, 09 Dec. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 22:46:32, 09 Dec. CWMP: HDM socket closed successfully. 22:46:32, 09 Dec. CWMP: HDM socket opened successfully. 22:46:32, 09 Dec. CWMP: Set Parameter by TR069 Success. 22:46:31, 09 Dec. CWMP: HDM socket closed successfully. 22:46:31, 09 Dec. CWMP: HDM socket opened successfully. 22:46:30, 09 Dec. CWMP: HDM socket closed successfully. 22:46:30, 09 Dec. CWMP: HDM socket opened successfully. 22:46:30, 09 Dec. CWMP: session completed successfully 22:46:30, 09 Dec. CWMP: HDM socket closed successfully. 22:46:30, 09 Dec. CWMP: HDM socket opened successfully. 22:46:29, 09 Dec. CWMP: Server URL: https://ee.x.x; Connecting as user: ACS username 22:46:29, 09 Dec. CWMP: Session start now, server: https://ee.x.x, Event code: 22:46:29, 09 Dec. CWMP: Initializing transaction for event code 2 PERIODIC 22:13:34, 09 Dec. admin login success from 192.168.1.216 21:45:31, 09 Dec. CWMP: HDM socket closed successfully. 21:45:31, 09 Dec. CWMP: HDM socket opened successfully. 21:45:30, 09 Dec. CWMP: Set Parameter by TR069 Success. 21:45:30, 09 Dec. CWMP: HDM socket closed successfully. 21:45:29, 09 Dec. CWMP: HDM socket opened successfully. 21:45:29, 09 Dec. CWMP: session completed successfully 21:45:29, 09 Dec. CWMP: HDM socket closed successfully. 21:45:29, 09 Dec. CWMP: HDM socket opened successfully. 21:45:29, 09 Dec. CWMP: Server URL: https://ee.x.x; Connecting as user: ACS username 21:45:29, 09 Dec. CWMP: Session start now, server: https://ee.x.x, Event code: 21:45:29, 09 Dec. CWMP: Initializing transaction for event code 2 PERIODIC 20:30:59, 09 Dec. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 20:30:58, 09 Dec. Receive a DHCP request 20:15:30, 09 Dec. CWMP: HDM socket closed successfully. 20:15:30, 09 Dec. CWMP: HDM socket opened successfully. 20:15:30, 09 Dec. CWMP: Set Parameter by TR069 Success. 20:15:29, 09 Dec. CWMP: HDM socket closed successfully. 20:15:29, 09 Dec. CWMP: HDM socket opened successfully. 20:15:28, 09 Dec. CWMP: HDM socket closed successfully. 20:15:27, 09 Dec. CWMP: HDM socket opened successfully.
10-12-2020 11:06 AM
This was where the upgrade happened but still showed
00:52:53, 05 Dec. DSL Link Up: Down Rate=29059kbps, Up Rate=6750kbps; SNR Margin
it has gradually become slower 28mbps 27mbps.... now 25mbps..............
db919d0232c431c4, lease duration is 86400 seconds
00:57:37, 05 Dec. 2.4G Client associate from 88:ad:d2:d9:80:28 (IP=192.168.1.228) RSSI=-31, Rate=1Mbps, host android-db919d0232c431c4 00:57:37, 05 Dec. Receive a DHCP request 00:57:36, 05 Dec. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 00:53:26, 05 Dec. NTP synchronization success 00:53:11, 05 Dec. WAN Sensing Auto sensing Complete, interface selected 00:53:10, 05 Dec. NTP synchronization start 00:53:09, 05 Dec. WAN DHCPv6 events: INIT 00:53:06, 05 Dec. WAN Sensing Auto sensing Running 00:53:06, 05 Dec. Success - secondary DNS servers 00:53:06, 05 Dec. Success - primary DNS servers 00:53:06, 05 Dec. WAN connection WAN2_INTERNET_PTM connected 00:52:58, 05 Dec. 5G WiFi auto selected channel 40 Bandwidth:80M(Reason:boot) 00:52:57, 05 Dec. 2.4G WiFi auto selected channel 6 Bandwidth:20M(Reason:boot) 00:52:53, 05 Dec. WAN Auto-sensing detected port DSL WAN 00:52:53, 05 Dec. DSL Link Up: Down Rate=29059kbps, Up Rate=6750kbps; SNR Margin Down=6.3dB, Up=6.0dB 00:51:58, 05 Dec. Booting firmware v0.06.01.08190-EE (Wed Aug 19 18:20:33 2020) 00:51:57, 05 Dec. Upgrade and system start TR069 00:51:56, 05 Dec. System up 00:51:56, 05 Dec. Detect and configure Ethernet port1 as LAN 00:51:56, 05 Dec. Hub has activated against the device management system 00:51:56, 05 Dec. WAN Auto-sensing last connection port: DSL WAN 00:49:02, 05 Dec. NTP synchronization success 00:48:52, 05 Dec. WAN Sensing Auto sensing Complete, interface selected 00:48:49, 05 Dec. NTP synchronization start 00:48:49, 05 Dec. WAN DHCPv6 events: INIT 00:48:46, 05 Dec. WAN Sensing Auto sensing Running 00:48:46, 05 Dec. Success - secondary DNS servers 00:48:46, 05 Dec. Success - primary DNS servers 00:48:46, 05 Dec. WAN connection WAN2_INTERNET_PTM connected 00:48:38, 05 Dec. 5G WiFi auto selected channel 40 Bandwidth:80M(Reason:boot) 00:48:37, 05 Dec. 2.4G WiFi auto selected channel 1 Bandwidth:20M(Reason:boot) 00:48:33, 05 Dec. WAN Auto-sensing detected port DSL WAN 00:48:33, 05 Dec. DSL Link Up: Down Rate=29036kbps, Up Rate=6690kbps; SNR Margin Down=6.1dB, Up=6.0dB 00:47:38, 05 Dec. Booting firmware v0.05.02.04290-EE (Wed Apr 29 18:51:15 2020) 00:47:37, 05 Dec. Upgrade and system start TR069 00:47:37, 05 Dec. System up 00:47:36, 05 Dec. Detect and configure Ethernet port1 as LAN 00:47:36, 05 Dec. Hub has activated against the device management system 00:47:36, 05 Dec. Hub has activated against the device management system 00:47:36, 05 Dec. WAN Auto-sensing last connection port: DSL WAN 00:10:34, 05 Dec. A device disconnected from Ethernet port 1 00:10:34, 05 Dec. Wire Lan Port 1 down, Speed 10 Mbps 00:10:22, 05 Dec. A device connected to Ethernet port 1 00:10:22, 05 Dec. Wire Lan Port 1 up, Speed 10 Mbps 00:10:21, 05 Dec. DHCP device Disconnected: 192.168.1.216, ec:8e:b5:d9:52:48, DESKTOP-CIT2O45 00:10:20, 05 Dec. A device disconnected from Ethernet port 1 00:10:20, 05 Dec. Wire Lan Port 1 down, Speed 10 Mbps 23:30:10, 04 Dec. Receive a DHCP request 17:56:24, 04 Dec. NTP synchronization success 17:56:08, 04 Dec. WAN Sensing Auto sensing Complete, interface selected 17:56:06, 04 Dec. WAN DHCPv6 events: INIT 17:56:06, 04 Dec. NTP synchronization start 17:56:02, 04 Dec. WAN Sensing Auto sensing Running 17:56:02, 04 Dec. Success - secondary DNS servers 17:56:02, 04 Dec. Success - primary DNS servers 17:56:02, 04 Dec. WAN connection WAN2_INTERNET_PTM connected 17:55:30, 04 Dec. WAN Auto-sensing detected port DSL WAN 17:55:30, 04 Dec. DSL Link Up: Down Rate=28386kbps, Up Rate=6818kbps; SNR Margin Down=6.1dB, Up=6.0dB
10-12-2020 11:13 AM
BT DATA
VDSL Range A (Clean) 45.3 32.4 8 6.1 25 Available Available --
VDSL Range B (Impacted)44.1 26.5 8 5.9 20 Available Available --
Max Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
| 27.63 | 3.79 |
| 6.81 | 1.19 |
| 2020-11-10 | 2020-08-15 |
