18-11-2021 10:41 PM
I travel a lot for work all over the uk and everywhere I go and stay EE signal is so crap 1 maybe 2 bars.
I don’t even get signal at home 0 bars city of Manchester higher Blackley.., how can this be right.
I have 4 contracts with this company and all due for renew and not one will get upgraded.
it is like have a dial up modem where ever I go.
18-11-2021 10:54 PM
Hi @Richpongo8
If you're having problems in specific locations, I'd recommend checking the coverage & status checker ("check status" for the faults lookup)
If, as your posts suggest, your problems are widespread, you may have a fault with your devices. Do other EE users in these same locations also have similar problems?
