close
EE Smart Hub question
crashzone
Valued Contributor
Valued Contributor
I'm on fiber plus but for some reason the router stats are showing low sync speeds.
Data rate:15.00 Mbps / 20.00 Mbps
Maximum data rate:16.44 Mbps / 56.71 Mbps
Do I just ring the number and ask a techie to fix it?  Or is there something I can do at this end.
Contract promise:
Minimum Fibre Download Speed is 46.2 Mb/Sec
Maximum Fibre Download Speed is 51.4 Mb/Sec
Minimum Fibre Upload Speed is 15.6 Mb/Sec
Maximum Fibre Upload Speed is 17.3 Mb/Sec
Minimum Guaranteed Download Speed is 41.60 Mb/Sec
8 REPLIES 8
How long has it been like this? Has any  work been going on in your neighbour hood recently
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
crashzone
Valued Contributor
Valued Contributor
router stats
Product name:Smart Hub
Serial number:+EEH001+2031005841
Firmware version:v0.06.01.08190-EE
Firmware updated:Sat Feb 27 02:00:46 2021
Board version:01
DSL uptime:4 Days, 22 Hours, 2 Mins, 50 Secs
Maximum data rate:16.44 Mbps / 56.68 Mbps
Noise margin (up/down):7.2 / 19.1
Line attenuation (up/down):23.9 / 18.6
Signal attenuation (up/down):23.7 / 18.6
Data sent / received:8.8 GB / 171.6 GB
2.4 GHz wireless network name:EE-Hub-8Rs8
2.4 GHz wireless channel:Smart (Channel 1)
5 GHz wireless network name:5GHz-EE-Hub-8Rs8
5 GHz wireless channel:Smart (Channel 48)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:EC:6C:9A:56:EB:54
Software variant:-
Boot loader:0.0.3-EE (Mon Dec 4 17:32:53 2017
I have the BT activity checker info but can't seem to copy and paste it.  Any instructions on how to do tat would be good.  None techie at work here..
pip11
Scholarly Contributor
Just take a screenshot of the availabilt
2021-07-03 08_21_48-Post a community reply - The EE Community — Mozilla Firefox.png
It will need mod approval before it shows.
Meanwhile, check you have a dial tone and check for noise on the line 17070 option 2.
crashzone
Valued Contributor
Valued Contributor
Thanks pip11
Dial tone and noise checked. No noise and dial tone is there.
Here is the screen shot, hopefully...
The DLM system has put you on a banded profile in response to past errors on your line, at the top of the up to 20 Meg band of these VDSL Banded Profiles. You need to give the DLM time to relent & remove any banding. If your sync speed at the test socket remains stuck at the same speed for 10 days you should ask EE to investigate the underlying fault. If a fault is found and fixed then the OR engineer may request a DLM reset. However should significant errors persist the DLM will reapply banding.
crashzone
Valued Contributor
Valued Contributor
Thanks everyone
Had EE engineer out yesterday and now the OR engineer is coming on Monday.  Hopefully he can fix the problem.
The speed reduction happened suddenly and I guess DLM could well have kicked in.  Fingers crossed it's a fault that's relatively easy to fix.
pip11
EE don't have engineers.
crashzone
Valued Contributor
Valued Contributor
Okay, the tech guy they sent around.
