For up-to-date information and comments, search the EE Community or start a new topic.  |
13-12-2021 11:54 AM - edited 13-12-2021 11:59 AM
There's an issue with the EE community website where CORS is causing the icons not to show in most modern browsers.
Please pass to the relevant team to fix 🙂
Thanks,
Alex
13-12-2021 11:58 AM
13-12-2021 11:58 AM
Thanks, @Alex_M 🙂
This is way above my level of expertise at the moment.
I've passed it on for investigation though.
Thanks again.
13-12-2021 11:58 AM
Cheers @Profile closed and @Sean_D !
13-12-2021 12:25 PM
Hi @Alex_M,
Thanks for highlighting this. I will raise a ticket to our supplier to find out what is causing the issue.
Thanks, @Profile closed for the head up 👍
I will update this thread as soon as I know more.
Cheers
Sean
14-12-2021 12:22 PM
Hi @Alex_M,
Good afternoon, I hope you are keeping well.
Khoros support has dropped me an update. They have not been able to replicate the issue from their end. They also doubled checked the CORS Config and have confirmed that this looks good so they are unable to explain your experience.
Hopefully, this was a temporary issue but can you confirm if you are still facing the same problem?
Cheers
Sean
