03-09-2020 02:36 PM
Just looking to know how i go about making my ee sim in to an e sim for the iphone 11 pro to make benefit out of the dual sim possibilities
03-09-2020 02:42 PM
Hi @MATTHEWR
The easiest way is to pop into a store and they'll swap it over for you and give you a QR code. Just check if you need to book an appointment in advance and the store is open, and all that.
You can call and EE will send you an eSIM pack out but that;'ll cost you £1.50 and take a few days.
As long as you have an unlocked iPhone (or locked to EE), it's a simple process to swap over.
03-09-2020 02:51 PM
@MATTHEWR Just to add if your device is an EE device it’ll be locked to EE and this means only EE sims will work in it. Once you had the device for over 6 months you can request it to be unlocked HERE to then use any network sim you want in the device.
14-09-2020 02:58 PM
Super thanks for the information,
