01-02-2021 05:35 PM
Hi all, hope you are very well.
New user. Im looking into getting EE 4G wifi at home. I have some thick stone walls and a elongated home. So I will need a wifi extender(s) to boost the signal from the router. The person at EE I have been talking to tells me that the setup I would be provided with is '4G ee HOME ROUTER OR ROUTER 2', but doesnt know if it is possible to use wifi extenders with it.
Can anyone tell me if I can use a regular wifi extender with this setup please? Or if you have any other advice.
V much appreciated,
David.
01-02-2021 06:13 PM
Hi larksd.. I have a 4GEE router and as our house is quite long I use it with a booster without any problem - it just needs setting up with your wifi. My advice would be to buy a decent one - don't be tempted by the £30-40 jobbies. I have a TP Link RE450 which does the job well for me; if you think the chunky walls might be a problem the RE650 might be better for you.
16-01-2022 02:11 PM
Hi I’m looking into same thing
24-01-2022 03:33 PM
I can also confirm wifi extenders/powerline adapters worked with my 4GEE.
I've switched over to using Unifi Access Points instead now though as I found the connections on the adapters not great but thats not an EE thing but more because my house wiring probably isn't up to par.
