close
Currently on EE Sim plan but want to move to EE Phone and Sim question.
Dizziz
Right now I'm on a Monthly Sim plan and I have a discount from work for EE so I want to use it. Now I want to get the new iPhone 13 Pro Max with 100GB package, however I want to keep my current number.
If I check out and get this deal, will I keep my same number or will I have to go through some process of porting my Monthly Sim Plan number?
Just curious if they'll send me a Sim with a new number or will I have to first get a PAC for this Sim to port it? I'm a little stumped.
Cheers.
@Dizziz   I’d this an upgrade?   You’ll retain your number if you are doing this as an upgrade.
Yes, it'll be an upgrade, been due one for a VERY long time now.
Thank you for the answer, really appreciate it. 🙌🏻
