| For up-to-date information and comments, search the EE Community or start a new topic. |
07-08-2021 08:57 PM - edited 07-08-2021 09:01 PM
Has anyone else had issues with having poor connections to specific sites?
I am having regular issues watching youtube, buffering even low-resolution videos. It is just me in the house and of all the times I have done a speed check, I don't remember ever getting below 70Mb/s.
I want to know If EE is/has to throttle specific sites that have both high amounts of users and data requirements such as Youtube?
Has anyone with the same issue had any luck switching DNS or by some other method?
After reading some other threads I should add: I have an iPhone, but I mainly use and am having issues with a PC. That, and with the speed checks, I am confident It is not a Wifi connection issue or something similar that has been suggested elsewhere.
Ta'
07-08-2021 09:03 PM
EE don't throttle your connection or even any particular sites.
07-08-2021 11:52 PM
Hi @ashreid20 ,
In addition to the above very good advice, YouTube has the inbuilt tool "stats for nerds" allowing you to monitor the real-time bandwidth and buffer health which may be of usage in understanding the issue.
It can usually be found fairly easily in the options but the below will help locate the tool.
08-08-2021 10:07 AM - edited 08-08-2021 10:23 AM
thanks for the response
~~roiuter stats~~
Serial number:+EEH001+##########
Firmware version:v0.06.01.08190-EE
2.4 GHz wireless network name:EE-Hub-#######
5 GHz wireless network name:EE-Hub-########
Wireless security:WPA2
Firewall:Default
MAC address:###########
Software variant:-
Boot loader:0.0.3-EE (Mon Dec 4 17:32:53 2017)
~~wired speedtest~~
https://www.thinkbroadband.com/speedtest/1628413124830972255
~~Wholesale Availability~~
| Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate (Mbps) | Downstream HandbackThreshold(Mbps) | WBC FTTC Availability Date | WBC SOGEA Availability Date | ||
| High | Low | High | Low | ||||
| VDSL Range A (Clean) | 80 | 70 | 20 | 19 | 64.3 | Waiting list | Waiting list |
| VDSL Range B (Impacted) | 80 | 67 | 20 | 19 | 60 | Waiting list | Waiting list |
| Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate (Mbps) | Downstream Range (Mbps) | Availability Date | FTTP Install Process |
| FTTP on Demand | 330 | 50 | -- | Available | -- |
| ADSL Products | Downstream Line Rate (Mbps) | Upstream Line Rate (Mbps) | Downstream Range(Mbps) | Availability Date |
| WBC ADSL 2+ | Up to 12 | -- | 7 to 17 | Available |
| WBC ADSL2+ Annex M | Up to 12 | Up to 1 | 7 to 17 | Available |
| ADSL Max | Up to 6.5 | -- | 5.5 to 8 | Available |
| WBC Fixed Rate | -- | -- | -- | Available |
| Other Offerings | Availability Date |
| VDSL Multicast | Available |
| ADSL Multicast | Available |
| Exchange Product Restrictions | Status |
| FTTP Priority Exchange | N |
| WLR Withdrawal | N |
| SOADSL Restriction | Y |
08-08-2021 11:36 AM
I have seen the nerds tool before, but I don't know how it can help me beyond telling me that my network might sit at 45-65mb/s for a bit when it is working well, then drop to maybe 10-12mb/s and show me a count of the frames I lost when the video buffers.
08-08-2021 01:11 PM
Thanks. Everything looks good.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
08-08-2021 03:34 PM - edited 08-08-2021 04:23 PM
Hi @ashreid20 ,
"Stats for nerds" exists to debug the issue which you have reported. It is not mandatory to use it if you have a better tool that serves the same purpose. Good luck!
https://support.google.com/youtube/answer/7519898
Per the CNET link, a 480p stream only requires 1.1 Mbps which is far below the numbers which you speculated might explain the problem. Sitting at 10 Mbps does not explain.
If there's anything causing that particular video at that particular resolution to be throttled, or one or more YouTube servers to be throttled for whatever reason, stats for nerds would show this directly with sub 1.1 Mbps sustained for longer than 30 seconds and the buffer emptying. I.e. it would answer your question of whether there is any throttling (it may not be deliberate throttling but congestion causing indirect or incidental throttling that may not occur for a more popular video or different copy/resolution).
