Community Activity
Mountly plan
I want to open mountly plan
Pensions
HiI'm a previous employee (2010-2014). Would someone be able to contact me regarding my pension plan please?Many thanksKatheine
Wifi 7 Extenders
Hi - Has anyone any experience of the new WiFi 7 Extenders? I have three attached to a hub pro. It seems the best I can get speed is around 200 - 300. Are the Extenders limited in speed? Had significant issues with the new hub pro by itself. On the a...
Can't make international calls from Taiwan
Hello, I am having the same issue calling the UK from Taiwan. I have activated the option so that my UK data and calls can be used in Taiwan for 24 hrs to enable calls but I all calls are failing - including 150 to EE. Help!
Discovery plus activation
HELP! I have been trying tom activate my discovery+ for over a month and in total I have spent 8 hrs trying!I have the code to activate it on my tv screen but NOTHING works! I opened a discovery+ account that didn't work. I open the EE link that only...
Using inclusive extras
Hi can anyone help me please I have the Xbox game pass as my inclusive extra. How do I set it up or link it to my xbox account? Thanks in advance.
Are you Ee company? I am your customer. You are a fraudulent company. My bill wa
Are you Ee company? I am your customer. You are a fraudulent company. My bill was 120 and now it is 140. And the network is worse than all of your C's. The networks used are better. Than your networks. Always miserable. There is no internet and we pa...
Upgrading
Hello,if I upgrade when abroad will they disconnect and send a new sim or will the existing e-sim keep working on the new plan?
Is this spam?
received this text today, could you tell me if it’s spam or not? Says it’s from EE, if I click info there’s nothing there. But as you can see I did receive a security message from the same provider?
Test broadband speed
Am trying to test broadband speed by following instructions on EE webpage which says:Open the EE app.Select Manage.Select Broadband.Select See what’s included in your plan to get a breakdown on what you’re expecting.You can select a Test speed from t...
