close
Broadband router reseting frequently
GerryCoppell
Does anyone know what would cause my router to suddenly start resetting itself 3 or 4 times a day.
Is it the BB as a whole dropping or just the WiFi connections? What colours are the light sequence when it happens?
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
All the green lights go out with just the status light turning a king of pale red. This then goes out so all lights are off. Then the status light goes red and the router starts its restart cycle until all green lights are back on again and we can reconnect.
Christopher_G
Hi @GerryCoppell
Welcome to the community. 🙂
Are you able to find and post the stats that @XRaySpeX has asked for?
