06-04-2021 09:57 AM
Could anyone tell me if my three collected boosts carry on if a add on is applied ? or are they wiped back to zero in the same way changing pack would??
ta ..
06-04-2021 11:36 AM
Morning @apw987
Thanks for posting on the community 🙂
Purchasing an add-on should not affect your free boosts, you would loose the free boosts if you changed to a from a 30-day pack (£10 or above) to a seven-day £1 pack, or vice versa, you'll lose any Free Boosts you have and will need to buy the required number of packs again to get another Free Boost.
If you buy a 30-day pack less than £10 and change to any other pack or vice versa, you’ll lose any Free Boosts you’ve earned.
You can find information in our What are EE Free Boosts? Help page.
Thanks 🙂
06-04-2021 11:36 AM
Morning @apw987
Thanks 🙂
