close
Blocked website
HenGogledd
I have set my settings to allow all content ie no filters, I have oodles of data available. I have no problem with other Zoom services,  however my wife's online gym class website seems unavailable.  The website is working- I have checked using the same device on a different network.
Any ideas?
1 ACCEPTED SOLUTION
I was informed she had done that.
However the simple expedient of "Have you tried turning it on and off again?" worked.
Always check for yourself!
Ta
6 REPLIES 6
Hi @HenGogledd
What is the website you're having problems accessing?
Can you explain what you mean by "seems unavailable" - what happens when you try to load this site?
the site is www.ablefitness.co.uk.
Most browsers indicate that the site is unavailable.  I have used PING and the result is a "request for timeout"
James_B
EE Community Manager
Hi @HenGogledd,
I'm able to access the website over EE Broadband and via EE mobile data. What devices are you using?
I've loaded that site over an EE mobile connection here ok, no problems.
I know it's basic, but have you tried restarting the affected devices (router included) and clearing the temporary files/cache?
Ta
James_B
Glad you got it sorted @HenGogledd 🙂
