24-05-2021 08:39 AM
My 4G EE router, Huawei B625-261 seems to drop download/upload speed daily. I can only think that it updates/restarts in the night, and every morning is running slow. Odd thing though is that it takes more than one restart to fix. Runs fine all day, then same thing next morning. Its not wifi, as some devices are wired to the router, and the speed problem is the same on all devices.
Is there something I can do?
20-06-2021 09:28 AM
Thx Essex Boy
results below:
GOOD
log:
RSRQ-3.0dB RSRP-81dBm SINR20dB
API:
401 3353089 -3.0dB -82dBm -61dBm 20dB 7 20MHz 20MHz PPusch:-4dBm PPucch:-20dBm PSrs:3dBm PPrach:-5dBm mcsUpCarrier1:22 mcsDownCarrier1Code0:0 mcsDownCarrier1Code1:28 DL:1617 UL:19617 10661 3 No1:323No2:399 23430 0 17517 18467 TM[3] 0013098 14 14 1751700kHz 1846700kHz
BAD
log:RSRQ-7.0dB RSRP-108dBm SINR1dB
API:
463 3351813 -10.0dB -108dBm -81dBm 1dB 7 10MHz 10MHz PPusch:22dBm PPucch:11dBm PSrs:5dBm PPrach:23dBm mcsUpCarrier1:4 mcsDownCarrier1Code0:6 mcsDownCarrier1Code1:5 DL:1761 UL:19761 10661 3 23430 0 17661 18611 TM[3] 0013093 6 6 1766100kHz 1861100kHz
Also noticed that I dont have to reset the router to fix, if i redo the manual or auto search under mobile network searching it fixes.
