on 19-09-2020 09:51 PM
I read somewhere a while ago that the 4GEE mini contains a GPS tracker. Is this true?
on 19-09-2020 10:25 PM
No!
on 19-09-2020 10:49 PM
Are you sure? I’m putting it on an internet security blog and I don’t want to say it if it’s wrong. Sorry if I sound rude
on 19-09-2020 11:47 PM
No mention of GPS in its product spec:
Product details of Alcatel EE40 4G Portable MIFI Hotspot Modem
- 4G BAND: LTE 800 / 1800 / 2600 MHz
- 3G BAND: DC-HSPA+/HSPA+/HSPA/UMTS 900 / 1800 / 2100 MHz
- 2G BAND: GSM/GPRS/EDGE 850/900/1800/1900 MHz
- 4G SPEED:
- LTE DL Speed up to 150 Mbit/s
- LTE UL Speed up to 50 Mbit/s
- 3G SPEED:
- DC-HSPA+DL (DOWNLOAD) up to 43.2Mbps
- DC-HSPA+UL (UPLOAD) up to 5.76Mbps
- HARDWARE:
- 1500 mAH Battery up to 6 hr operation , standby 50hr
- Micro USB interface ,Sim Card Slot
- LED Indicator for signal strength , network selection (4G / 3G) , SMS
- Power Switch , Reset Switch
- Dimension (height x width x depth) : 70mm × 70mm × 13mm
- Weight : about 90g (including battery)
- SOFTWARE :
- SMS - sending / receiving , inbox (storage)
- Wifi Setting - SSID / Login PW / TKIP / AES / MAX Number of User ( up to 15 users)
- DHCP - Adjusted IP Home address, DHCP Server , DHCP IP POOT , DHCP IP POOL , DHCP IP Lease Time ,Mac FIlter
- Profile Management - AUTO APN , Manual APN
- Network Mode - AUTO , 4G ONLY , 3G ONLY , Manual Search function
- Connection mode - Automatic / Manual
nor in the EE Osprey Mini, its predecessor & lookalike, which I possess.
