iPhone 11 freezes when I call
Bec47
When I make a call it freezes and I can’t close the call tab
I miss calls as it doesn’t ring
I can make calls every now and then but on between it freezing
can anyone help??
Northerner
Hi @Bec47
Try backing up and factory resetting.
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
Leanne_T
Hi @Bec47
Could you try the advice from @Northerner and back up all you data and factory reset your iPhone.
Once this has been done can you test the iPhone to see if this continues?
Thanks 🙂
