12-10-2025 12:22 PM
Phone said battery was low put on charge overnight and now doesn’t turn on. It doesn’t do anything at all.
not been dropped
12-10-2025 12:34 PM
@M4edwards22576 , how long have you had your phone?
Is your charger working properly? You may want to check, as it could be the charger is faulty. Where did you get your charger? Cheap ones can become defective.
12-10-2025 01:28 PM
12-10-2025 03:10 PM
Tried a soft reset.
Make sure the port is clean as well.
12-10-2025 11:35 PM
Hi I do believe it is under a year old but can’t remember when I bought it
12-10-2025 11:36 PM
The phone won’t even turn on even when plugged into a apple approved charger
12-10-2025 11:40 PM
It was purchased in December 2023 so would be out of warrenty right??
13-10-2025 12:25 AM
@M4edwards22576 , yes it would be out of warranty, but even if the charger is an Apple one, it could develop a fault, so worth trying another charger, to see if that resolves the matter, as the battery should still charge up, as the phone is not that old, it should still be able to charge, as I have an even older phone that will still charge if needed.
