08-11-2023 09:49 AM
iPhone 14 pro
note the new notification blue bullet point and the red bubble over the voice mail key at the bottom right
phantom notification the last few days. Have deleted all voicemails via the network provider EE dial in service.
have switched on and off all notifications
have texted 150 to turn off voicemail completely
can anyone advise. Thanks
08-11-2023 12:25 PM
Could you try leaving yourself a voicemail from another phone, then listen to the full message before deleting please?
Let me know if the voicemail indicator then goes.
08-11-2023 12:25 PM
22-03-2024 11:24 AM
Hi
I am also having the same problem been on there for months now went to EE shop with no success there either please can you help
many thanks
seb
22-03-2024 11:48 AM
Hi @Mrseb,
Did you try @Christopher_G's tip to leave a new voicemail and listen to it in full before deleting?
23-03-2024 12:44 AM
23-03-2024 08:04 AM
05-05-2024 04:11 PM
Thank you! I've just tried this and it worked for me too. That red dot was driving me nuts!!!
03-12-2024 01:29 PM
Im having this issue, ive tried leaving a number of voicemails and then deleting them but the phantom notification is still there as is the red bubble.
03-12-2024 03:39 PM
Hi @Barrypepe
If the steps in the solution from @Christopher_G haven't worked for you, please contact Customer Service where a guide will be able to reset your voicemail notification for you.
Please let us know how you get on.
Ali
10-12-2024 11:14 AM
Hi Paul,
So I now have this ; having just upgraded my SIM with EE.
Leaving myself a message creates a new visual Voicemail item which works fine to listen (and later delete) ; but calling Network Provider continues to say there are No Messages even when I'v left one.
Help please ?
Geoff
