My iPhone 15 pro max was stolen and I have reported it to ee to block the phone
Janeeric
My iPhone 15 Pro max was stolen and I have reported it to ee can whoever stolen it still be able to use it on calls or WiFi connection? Please thanks
@Janeeric  If it was password protected then no they can not use it.   They’ll need your passcode to gain access to it.    If it wasn’t passcode protected I highly recommend you change your passwords for all the apps you had on the device.
You also need to use to login to your iCloud account on a PC/Mac and go to find my you might be able to find the device as find my is enabled by default.  You can also mark the device as lost.
 Please see THIS
Janeeric
My iPhone 15 Pro max was stolen and I have reported it to ee to block the phone..  can whoever stolen it still be able to use it on calls or WiFi connection? Please thanks
@Janeeric : They will be able to use it over WiFi but not over the mobile network if EE blocked it.
 Please see THIS
Katie_J
Hello @Janeeric
Welcome to the community.
If your SIM has been suspended and the phone has been blacklisted the phone will not be able to be used.
Katie
uvarvu
Whatever you do, DON’T deregister your Apple ID from that phone.   That way it will remain a paperweight.  Sure, it can still be broken down into parts but at least the value won’t be as high.
