10-10-2022 09:38 PM
Mobile data went down, message I had to update via my Mac, spent hours doing this and it failed at the last. Then started working again. Then stopped working again. Tried to update again, again failed. Works again, then stops working, rendering phone unusable. Advice?
11-10-2022 08:44 AM
Hi @capott.
Is your phone currently on the latest software?
Is mobile data switched on and do you have a signal on the phone?
Jon
11-10-2022 09:11 AM
Yes, updated to 16.0.2, done hard reset, nothing cures. Last night it came back momentarily only to disappear again. I have wifi working on the phone but no signal at all (the bars undulate continuously)
11-10-2022 11:20 AM
11-10-2022 02:09 PM
Hi Jon, yes I have spare data, emptied a lot out yesterday as it was quite full. And yes I was asked to update, first to 15. something and then to 16.0.2, neither made any difference.Bit gloomy, feel like it's a hardware issue and I'm not under warranty
11-10-2022 03:17 PM
Sorry @capott I mean mobile data not data storage.
Can you check in your My EE Account to see if you have mobile data remaining?
Jon
11-10-2022 04:00 PM
Sorry, should have understood. Yes, I have masses remaining on my account.
11-10-2022 05:36 PM
Thanks @capott.
Are you with anyone else who's on EE and having problems with their mobile data? Could you check to see if there are any maintenance works in your area?
If you think it's a hardware problem it may be worth speaking to our technical support team to run through your options.
11-10-2022 06:54 PM
Maybe try to order new Sim card 🙂
11-10-2022 06:56 PM
Hi Chris, My husband has the identical phone with EE, no problems. I'm going to see an Apple Genius tomorrow morning, but I ran through quite a lot yesterday with technical support online when I had to give up for time constraints. Thanks for the suggestions anyway, Carolyn
