28-01-2022 08:09 PM
My sons iphone8 has suddenly stopped connecting to wifi - the button is on grey and won’t slide to on. We have tried restarting, even restoring to factory settings etc but the wifi still won’t work. The phone apart from this works fine, it’s just using all his data very quickly. Any advice?
28-01-2022 08:41 PM
What's the source of the WiFi?
28-01-2022 08:44 PM
It’s just our home wifi - we have ee broadband and also a 3 4g hub. No problems with either for any other device no the house, it is working completely fine.
28-01-2022 09:39 PM
Hi @LynnPat ,
Have you already followed Apple's official advice and contacted their technical support once you reach the end of the things to try?
https://support.apple.com/en-gb/HT204051
28-01-2022 10:02 PM
@LynnPat If it’s greyed out and you have factory reset the device and it’s still greyed out then unfortunately the device Wi-Fi is broken. This could be a simple fix as the cable could of just come off the Wi-Fi antenna within the device. It could be more. Have a look at THIS as it’s a step by step process on how to replace a Wi-Fi antenna but it’s not something I would recommend if you have never worked on an iPhone before. Apple can fix this but it’ll not be cheap you’ll probably be best with a 3rd party repair shop.
28-01-2022 10:08 PM
Thanks, was going to take it to a repair shop tomorrow but thought would ask in case we could sort it ourselves. Not keen to spend a lot to fix it but will see what they say.
28-01-2022 10:55 PM
Hi @LynnPat ,
As a personal opinion, I think it would be safer and cheaper to get Apple's input via online technical support and in an Apple Store first before going third party.
Hope it gets sorted. 🤓
29-01-2022 12:44 PM - edited 29-01-2022 12:51 PM
@LynnPat Out of warranty with apple will cost you £346.44 on an iPhone 8. You’ll need to make an apple appointment before you turn up at an Apple Store they will not deal with you if you just turn up. I’m pretty sure you’ll not get help online as they’ll need to run a remote diagnostics and that runs over Wi-Fi.
You can use this LINK to do just that.
@mikeliuk At least give a link for them to use to make an appointment.
