Hi i apply iphone 17pro mex when will i get
Chabankhan
Northerner
Hi @Chabankhan
Nobody can say for sure but if your application/upgrade is successful and your delivery due DPD will text you, but in the interim you can monitor EE order tracking.
Northerner
Hi @Chabankhan
Aloismiles
You'll more than likely have it in 28 days potentially more
I will travil 25 October i already tild him i need brfire 25 October
Aloismiles
I ordered mine on the 18th, 17 pro max 256 orange, I was told 21-28 days, if you look at the expected delivery dates they state 28 days for most models, deep blue 512gb or higher have shorter dispatch dates
