Esimm
Doadster63
I have a ee essentails  broadband and mobile contract on simfree can i purchase a new iphone in florida  converting my sim card to esim over here
Northerner
Hi @Doadster63
No, you'll need to be in the UK on the UK network to change your SIM over.
@Chris_B I assume an American iPhone will work although maybe not have all the same radio functionality as a European model?
@Northerner  it’ll work, all bandwidth supported on a US iPhone
See THIS
EE uses
2G
4G
  • 800MHz: (Band 20) - Long range, good for rural areas and indoors.
  • 1800MHz: (Band 3) - Primary capacity band.
  • 2100MHz: (Band 1) - Historically used for 3G, now for 4G.
  • 2600MHz: (Band 7 & Band 38) - High capacity, for dense urban areas.
5G
  • 700MHz: (Band 28) - Low frequency for broader coverage.
  • 1800MHz: (Band 3) - Used for 5G as well.
  • 2100MHz: (Band 1) - Also used for 5G services.
  • 2600MHz: (Band 7) - Higher frequencies for increased speed.
  • 3500/3600MHz: (NR Band 78) - High-speed, high-capacity band.
